Pollack Tank Selector Valve
RKBMKZ
Washington
Richard
K10 Cheyenne
5.3L
Hello all, just got my '77 K10 back from a 5.3 install, but having trouble with the selector valve. Got two brand new tanks from Tanks inc or PSI Conversions with Walboro internal pumps. The guy who installed it said the system runs between 58-62 psi and had a gauge on it to confirm. Just purchased a new 65 psi Pollack switch because the old one (happened to be the same) was acting strange. This one seemed to work initially until I saw fuel dumping from the opposite tank's overflow. Switched tanks and eventually the same thing. When using the right tank, a high pitched whistle comes from the valve, also.
What is happening is the tank in use is pushing fuel through the return line into the other tank for some reason. Has anyone seen this? Did I just happen to get the one bad selector? I know all the connections to the valve are correct and have had the truck running direct off either tanks so the lines are correct at the tanks.
Also looking for a toggle like the original square one (aux/main) with the correct amount of connections to use with this selector. The original is one short, I think; or I just don't know how to wire it up. I'd prefer not to use an aftermarket toggle switch.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I’ve seen this…
Trying to remember here, but if the wiring isn’t right the return will dump to the wrong tank and the pump will squall loudly. We did it when I was doing my ****** valve and EFI conversion
RKBMKZ
Washington
Richard
K10 Cheyenne
5.3L
I followed things to the T. Do you remember where the wiring was wrong? Maybe I'm an idiot. I've got two wires to each of the wires on the plug; one to the power and the other split to the pump. I even put a completely new wire to one so there was no question.
RKBMKZ
Washington
Richard
K10 Cheyenne
5.3L
There is one extra port on the plug, but there is nothing coming from it. Could that be where I supply power?
RKBMKZ
Washington
Richard
K10 Cheyenne
5.3L
Could there be a bad ground on the squeeling pump? I've had one tank down, but not the other. Doesn't seem the pump would work.
CalSgt
CA
Casey
IIRC, I crossed up these two splices somehow (on “D” and “E”)
CalSgt
CA
Casey
IIRC
If you hit one pump with power and power up the wrong wire at the switch it will do what you are describing. It’s been 2 years since I had this problem
RKBMKZ
Washington
Richard
K10 Cheyenne
5.3L
That actually makes sense. It's opening up the valve but running the opposite pump. I think I can just switch it at the toggle. We'll see. Thanks.
RKBMKZ
Washington
Richard
K10 Cheyenne
5.3L
If you lived in Spokane, I'd be driving a beer over to your house right now. Tried the toggle, the other pump just whined. Switched the power wire to the different pump; same thing. Changed the plug cable from D to E and E to D - no whine and just went for a 6-7 mile drive with no change in fuel level and no whine. I swear I thought of all the different permutations of this, but obviously missed that one. Thanks a ton
CalSgt
CA
Casey
AWESOME!
Glad it worked out for you
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Dang, I just got done doing the same thing, but missed out on the help, was at Bonneville, maybe next time. Love the easy fix, and CalSgt, knows his stuff
CalSgt
CA
Casey
Thanks for the confidence Sir... But even a blind squirrel finds a nut sometimes
FenderBanger
