please take look at this picture about to purchase c20
Shanex702x
las vegas
shane
attachment.php
this c20 has 36k original miles, what would all this oil be a sign of??any ideas will help, thank you
shane
I'm getting blocked by the site on mobile when I hit that link.
Sent from my iPod touch 4th Gen using Tapatalk
chunkyrzr
pellston, Michigan
carl
v2500
hopefully it came through and you can see it now
Driver4r
Nebraska
Trevor
k10,c20
Thats just a wore out pinion seal, Unsure about on a 14 bolt, but my 12bolt seal I changed it in 5 minutes.
Yeah it works now, I fixed the img tags. Like Trevor said, most likely pinion seal. Anybody here know if that seal can replaced without messing with the gears? Just pull the yoke and slap a new one in?
hirschdalechevy
norcal
rich
k-30
I have done a couple of mine and I marked the nut before removal , then put it back to the same mark , (maybe a tic more) , and used lock tight. No problems , it takes a lot to crush the crush sleeve.
However I did it two man style by hand , not with an impact gun.
Driver4r
Nebraska
Trevor
k10,c20
Marking the nut was 1 thing i forgot to do when i did mine.
89S, It doesnt mess with the gears as long as you get it tight, usually about the same tension as befor.
Hirsch: Yeh i 2 manned it also, I had a buddy hold a pipe wrench on the yolk and i had a flex handle on the nut.
Total time on mine litterally took 5 mins, a kid timed me lol.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Could be the gasket between the housing and the pinion support too.
Shanex702x
las vegas
shane
ok..I'm asking because I am driving overhere right now to start it again, check it out how that I've done over 10 hours of research on site..he wants 3, 36k original miles, pics in introduction, what is highest u guys would buy this vehicle for?would u ever go higher or what?i need any help right now guys, important to me, I have 44 minute drive start replying and take a look at my introduction!!!i only get 1 chance to haggle and know what I'm in for, thanks guys,
your new squarebody owner/member, Shane!
Shanex702x
las vegas
shane
he wants 3,000$$$ were about to negotiate from their,
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
If that's a 36k truck, I've got bridge for sale cheap...
Go with your gut man, and talk him down low as you can. Should have brought a knowledgeable mechanic friend along to help nit pick it and check it out for you. But you knew the asking price going there.
Shanex702x
las vegas
shane
I found more wrong with it, I tried he bailed on me didn't answer..imma get someone else to go with me this next weekend
sirex
