Please help 1976 K10 vacuum diagram
dirk22
sac
Dirk
Hi am am in need of some help I am looking for a vacuum diagram for a 1976 chevy k10 with 350 and non EGR any help would be great.
chengny
All the diagrams I have show every available confiuration (of the 1976 350) as having an EGR valve - and most used an EFE valve as well. Here is the simplest dwg I could find:
Fig. 5 Vacuum hose schematic-1976 V8 350 engine 4-bbl (Federal 4WD)
dirk22
sac
Dirk
Thanks for th chart but I am still looking for an non EGR.. I took it to the smog shop and they told me it did not need an EGR do I am a little confused.
Dirk
chengny
If they don't require an EGR, then just cap off the unused ports on the carburetor.
If you don't have an EGR valve, I doubt you have an EFE valve either.
With those two components not installed (or required to pass emissions) you can also remove the TVS's for them - if they still exist. Install pipe plugs where the TVS's were located.
So basically you will have only one vacuum line. It will go from the carb to the vacuum advance diaphragm on the distributor. Use one of the unported connections on the carb - that would be a small one way down low.
You also should have a larger hose running from the PCV valve on the valve cover to the large port on the carb. And - if you have vacuum assist power brakes - there will be another hose from the back of the carb over to the power brake actuator.
rich weyand
Bloomington Indiana
Rich
There will also be a vacuum line to the thermostat for the air door in the air cleaner snorkel if you have the stock air cleaner.
Obullard74
