SquareRoot
- Mar 18, 2017
- Arizona
- Mike
- K20
Replacing all seals in the 14 bolt ff today. Since I'm not replacing the gears or anything (except that obnoxious Detroit locker) I'm reusing what's currently there. Before I took the yoke off I marked it's alignment and used my inch pound beam torque wrench to check the pinion preload. Ha, it's ZERO! It's tight, smooth and no play but there's no bearing drag. I'm guessing the gearset takes a set over time and the pre-load goes away as things wear in?
So the question is, do I put it back to zero with no slop or add a few inch pounds?
