pcv and gromet
allan Johnson
monnesota
Allan
c15
need a pcv valve and gromet for the passenger side valve cover,they list about 5 sizes,which one do i need so i can get it without takin the old one out first,its in the rear of the stock tin vavle cover,thanks
is it next to the littrle bracket to hold the spark plug wires so one side has to be flat instead of circular?
like this
allan Johnson
monnesota
Allan
c15
nope,its all by is self on the rear of the passenger side
allan Johnson
monnesota
Allan
c15
nope its on the rear of the passenger side valve cover
then its probably a standard circular grommet. if you take the old one off, go to autozone or any store like that, go to the dorman HELP section and you should be able to match it up. Autozone near me has a hole selection of pcv grommets that I know for a fact would have a match for your valve cover. my valve covers are the same, but the passenger rear is my breather and its the same as the driver front, except flipped around so its in the back for the proper air flow.
I actually got one of the push in breather caps for it from autozone, they come in 2 different standard sizes i believe.
I should clarify, my passenger valve cover also has the oil fill which does technically make it different than the driver. otherwise yeah
allan Johnson
monnesota
Allan
c15
thanks my gromet is prolly orihinal and hard,leaks a little on the exhaust
Offrode
