passenger rear window switch
roy c
long island
roy
Hello again my rear passenger electric window switch brings window down but not up i was wondering if the driver door master switch might be defective i changed the switch on the rear door and it had the same problem
when i jumped the green wire with the center thicker stud the window went back up any help would be appriciated thanks roy
Here is the wiring diagram for a 4 door 1987 with power locks and windows:
If you can raise the window with a jumper (which is basicallly acting as a switch) there must be something wrong within the switch. Since you have a new switch, it is fairly safe to assume that the switch itself is not the issue. I would look closely at the wiring as it connects to the harness plug.
  • 4 dr windows and locks.pdf
roy c
long island
roy
rear driver side window
I placed a test light on the center post of the window switch when i pressed the switch up and down i was getting juice. on the down side window moved down but on the up side didn't move you think it might be time for a new motor? I noticed when i pressed from the driver door nothing up or down, but when i tested with the light i was getting juice there to.
There really isn't a center post - more like a line of 3 and a line of 2. They are connected as below:
Jumpimg "A" to either "C" or "D" will power the motor up or down - I can't tell which way.
If you are having trouble getting power from the switch to the motor, check the leads that go to the motor. They frequently get cut on the sharp sheetmetal of the door..
I don't think help like this can be found any other place :worthy:
defiftyae
CA
Fred
K20 Suburban
This is an excellent post with great info for my tailgate window that does not operate from the keyed switch. Thanks!!!
Dennis Blom
