Part
Ahh 10-4 Jeff. I was waiting for your tire size. Didn't realize you posted it up buddy. Sorry about that. I'm doing it right now. Be back in a few.
Here is the Forumula
#Drive Gear Teeth X Axle Ratio X (20168/Tire Diameter in inches) /1001 = # Driven Gear Teeth
That tire size equates to 28in Tall Tire.
If I did the math Right.
Gray 15 tooth Drive Gear on your output shaft should be a 34 tooth Lt Green Driven Gear
Red 17 tooth Drive Gear on your output shaft should be a 39 tooth Brown Driven Gear
Blue/Green 18 tooth Drive Gear on your output shaft should be a 41 tooth Yellow Driven Gear.
I'm going to take a guess and and say the Gray 15 tooth is more common. Now you having a Th400 in a half ton with a tall gear, makes yours possible to be uncommon, and why I gave you more than one option. You;ll need to stick a flashligh in the speedo hole and look at the color and/or count the teeth on your Drive gear to know which driven gear you need.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
thanks a lot .when I took the cable off before there was some yellow plastic on the end of the cable. I would guess thats why the speedo isn't working.does any tranny shop sell them?
Rock Auto has some $5 a piece.I"ve never had to buy one at a tranny shop. Usually found them at regulator auto store.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
HotRodPC i got these numbers off the adapter 1565180
1:1.363
342c6
would that help in getting the right gear
1:1.363
342c6
Not sure. I've never ordered using any #'s like that. I just tell them the color and how many teeth and if it's the big gear or the little gear.
Quiz
