Part
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
What is the name of the part that the speedo cable goes into on a400 tranny?will fluid come out if I take it off?
a: Speedometer Gear
b: No.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
It comes out at a right angle
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Tailshaft housing.
It may leakmif the truck is on a sloped driveway, or tilted towards the drivers side.
You shouldn't lose much fluid to pull the driven gear housing out of the case. Speedo gears go into the case, not tailshaft on a Th400.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
The plastic part that the cable goes into is broken.can I get replacement parts or should I hit the recycle yards
So you've got a broken drivin gear. Be sure to get the same color and/or gear teeth or your speedo will be wrong. Yes you can buy it. If your local parts store don't have it, you can get it online. It's going to be about $15 IIRC.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
I went from 273to 308 gears do toy know what color that would be
Ahh ****, I've been up all night. If noone else pops up with the formula today. By this afternoon, I should be able to tell you. Do you know which drive gear you have on the output shaft? That will matter. There is only 2 different ones. Maybe you can take a pic of where it enters the transmission and I should be able to tell which one. Either small gear or large gear. The Speedo housings are different for little gear and big gear on the output shaft, and what trans again?
Sometimes on your profile, where it says Engine, put your trans too and some even like to put ther rear end and ratio. Or have a a Signature with the paticulars. It really helps alot when some are trying to help. Notice mine says, 350/Th350/NP208.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
It's a 400 tranny in a 87 r10 with a 4.3 I'm out of town till Friday I'll shoot a pic then if it isn't raining
OK, for the 400 there is only 1 choice. So you have the big drive gear. Th350 has either one. Usually passenger car gets the small one and truck gets the bigger one, but I've seen both, either way too, so yours is the big one. If I don't get back here with the info, bump the thread. Gonna go check a couple other threads and get a nap before I get another call.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
hey HotRodPC have you found anything out ? if i were to get a new one who would i contact . thanks
Aha, here you are. I forgot which thread you were in. I need to know what size tire you're running. And to confirm, you were running 2.73's, now 3.08's right?
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
ive got 275-60 x 15 on the rear.yep 3.08 now
