paint code
grant
new jersey
grant
6.2 diesel
I found the sheet where the paint code should be but I can't find anything. maybe I am just stupid and can't see it? looked everywhere to see If it was etched in anywhere but no luck. the sicker on the door is only about tire pressure and max towing weight. Have any of you ran into this problem?? I can't find anything online about what It could be. looking of a paint code to do some touch up work and fix some rust before it gets too late. any options are much appreciated. below is a photo of the truck and the info sticker.
thanks
Your paint code is just the 17 listed.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
WA7468 is the GM paint code. That’ll make it way easier to find in stores for you.
Nowadays, yes. It used to be, the 2 digit code would be listed right along with the WA number.
grant
new jersey
grant
6.2 diesel
sweet you guys are the best, gonna try it out this weekend!
grant
new jersey
grant
6.2 diesel
33's, in the first photo it was on original leaf springs and 3" block in all 4 conners. In these photos its still the same tires but with the skyjacker 4" lift, no more blocks :). gonna try and swap them out for 35's after they wear out.
Stickman
