Overheating only highway speeds
NC
E.B.
V10 Burb
Hey fellas my 88 burb in only overheating on highway speeds. Running at normal temps when driving in and around town. I have your normal 350 EFI. Any ideas fellas? Thanks much
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
When was the coolant replaced? Is the radiator plugged inside? Is the radiator fins plugged or blocked?
NC
E.B.
V10 Burb
Actually it's been a while... I'll flush it and get back you guys with an update
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Do you have the spring in the lower radiator hose? If the spring isnt in the hose, at highway speeds, the hose collapses and will cause overheating. Also flush the coolant and install a new thermostat and gasket. Possibly replace your radiator hose also.
circuitguy
Elk Grove, CA
BIG-C
GMC 1/2 ton Stepside
Might have a plugged cat converter.
Could also be a bunch of leaves and junk plugged up in front of the bottom 4" of the radiator where you can't see.
87scotty
Central il
Andrew
V20
5.7 for now
All stock?
NC
E.B.
V10 Burb
Hey guys I flushed radiator and changed the stat, that did the trick. I really appreciate the help fellas.
twzorek
