- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Remember I put brand new heads on my TBI 350. These plugs are almost a year old. The mechanic that installed them told me that they are a heat range cooler than what is supposed to be on the motor. I ran them for the past 10 months and had a miss develop and traced it to these as you see, the #3 cylinder spark plug was built up with crap and wasn't firing.
I was assuming it was due to the cooler heat range and the plug was not hot enough to keep the crap blown off of it. I have heard many other opinions such as timing and a lean mixture causing this. I would like to hear more opinions on this and what direction I should go. For the mean time I installed the correct heat range plug and it's running fine. However I would like to fine tune the timing.
I have not had a chance yet but I am planning on pulling the #1 to find the true TDC. I believe my timing tab is bent and not showing an accurate reading under the timing light. So using the 'ol screwdriver through the spark plug hole method I am hoping to nail down exact TDC and time the engine from there.
I have no idea where to begin with trying to figure out if I am having a lean mixture issue. I am being told that the plugs should show a brown color and they are mostly white.
