- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Sorry hotrodpc, the 3/4 ton axle I was talking about is one that I was hoping to buy and put under my truck. Mine right now has a 10 bolt front and rear.
Ahhh, OK, we're crossing in posts here. Then you'll have to do some welding work to get that one to work in your truck. You might want to hold off on buying it if that's the case. It can end up very expensive. If you want to do this upgrade now, then you're better off getting a rear end out of a squarebody, ready to bolt in. I'll see if I can dig up the thread that explains and shows the difference in 14 bolt Semi Float and the 14 bolt Full Float.
