OK, I beat the **** out of the.....
73c20jim
Sierra Vista, AZ
C20 2WD Custom Deluxe
350 CID 195/260 HP Goodwrench crate
Ignition switch control rod. I straightened it out as best I could. The ends are clocked parallel.
Put it together and I easily inserted the rod into the ignition switch.
Should it go in so easily???
That means it can come out easily.
What is supposed to hold the rod securely into the switch???
I'm thinking of a loose tie strap to hold it in???
Help!
4WDKC
Southern Florida
Kacy
probably something similar
twitch1989
