Oil Leak
rgtrough
Dayton,Ohio
Bud
R10 Suburban
Hey guys, I have a 1987 Chevrolet R10 Suburban. All original. I have developed an oil leak. It appears to be coming from either the oil filter housing or above it. There appears to be a sensor above the oil filter housing. I’m assuming it is the oil pressure sensor. I think it is attached to the block through basic plumbing fittings. Is this correct? Is this a known problem? Any help is greatly appreciated.
Bud
Wumbo
Illinois
Rob
Oil pressure sensors can definitely leak oil. I replaced one a couple months ago that was leaking.
Of course it is. Put some UV dye in the crankcase if you’re doubting yourself, and hit it with a UV flashlight. It’ll lead you right to the source.
rgtrough
Dayton,Ohio
Bud
R10 Suburban
Thanks guys. I’ll try this.
Snoots
Roger
Jimmy Sierra
350 w/203
Or you can wash the area and then dust it with talc powder.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Could be the back of the manifold to block or where it intersects with the heads. This will leak down in your described areas.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
Bud
hose down the suspected area with carb or brake clean . fire it up and watch it. a pressure leak like a pressure sensor should show up pretty quick. if that doesn't work shut it off and watch. some leaks wont show with the engine idling because the PCV creates a negative pressure preventing the leak... had that on an oil pan not to long ago.. yes sensors leak and they are 1/8" pipe thread.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
don't forget to check the valve cover,they are notorious for leaks in that area
rgtrough
Dayton,Ohio
Bud
R10 Suburban
Thank you for all the replies. I change the valve cover gasket. That was not the problem. It is the oil pressure sensor. Thank you again for all your help.
rgtrough
Dayton,Ohio
Bud
R10 Suburban
Hey guys, changed out the oil pressure sending unit. Still have a leak. Starting from the bottom I pull the oil filter. Looks fine. Removed the oil cooler filter housing. The base gasket has a tiny crack in it. Replaced it and the other gasket that goes against the block. That’s it. No leak. Lesson learned. Start at the bottom and work your way up. Thanks guys
Dennis Blom
