Oil Cooler...factory option?
Shank
Michigan
Bob
K-10
Was an oil cooler a factory option on a 1986 K10?
My truck has one and the cooler itself was not mounted professionally. Just wondering if I should keep it and try to remount it to specs or to DC it.
Thanks in advance..
Bob
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
It should be factory, mine was mounted in front of the radiator and condenser and had two bolts going into the bottom of the radiator support to mount it, and the lines run through that front crossmember and have a band clamp to hold them still on the motor mounts then to the oil filter adapter
Shank
Michigan
Bob
K-10
Thanks Reaper!
Dennis Blom
