Odometer
9999
TX
82 K10 - Speedometer started bouncing and odometer quit turning. I pulled it out and lubed it up. Swapped in a LMC new cable, and with both no change. I believe it was routed wrong, it looped under the passenger side under the transfer case. I re routed the original over the transfer case and now the speedometer works.
But the odometer still doesn’t. Any ideas on the odometer except swapping it out?
85 Squarebody76
Missouri
Bob
GMC C1500
The odometer is driven by the speedometer gear inside the head... so if it don't work I would take it apart and lube the gear inside the speedometer that turns the odometer assy..
FenderBanger
