oasis hp 1000 onboard air
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
Dose anyone have one on there truck is it worth the money i have a chance to get one it would be nice... thoughts on this
Domer
El Cajon, Kalifornia
Kyle
6-71 Blown 355
Its a York engine driven compressor with a big ass electric motor.. they are nice if you don't have the room for an EDC. But that said, you need a hell of an electrical system to handle the draw of those motors. but they fill hella fast.. i loved my york i had on my truck setup as an EDC.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
I have two red top optimas with a diod 100 amp isolator you think id have to get a larger alt like a 180 amp or somthing then bigger isolator to match
Domer
Kyle
6-71 Blown 355
Not even close man...
Some specs on the Oasis HP1000:
17"Lx7"Wx10"H Wt.: 45 lbs
Motor Type: Series wound
Max Load Amps:200 @ 12vdc/
Max psi 200/ At Psi 100, CFM is 8 and draws Current of 180 amps.
Hit up jeremy at TRE 5 Customs and get a couple of big Kintek Batteries and some very larger wiring and relays.. you will need at least a 200 amp alternator
86_chev
