Blue Ox
Turning Diesel Fuel Into Fun
- Mar 27, 2018
- LI-NY
- Derek
- MCMLXXXV
- K20HD
- 6.2L
So this bushing and the rear most support bearing would take the brunt of the wear if there was an excessive runout condition at the yoke?
As long as the 1” creep to get it to change doesn’t get worse I’m not as concerned with that now. Mostly want to solve this vibration issue.
The yoke would be supported by the bushing more so than the shaft, so yes.
Gear Vendors instructions for shortening the driveshaft want the yoke extended 1/2"-5/8" from bottomed. If you have a lift kit etc you might go a little longer depending on the arc of driveshaft travel.
