scenic760
- Jan 12, 2021
- SoCal
- Chris
- Suburban K10
I have dove into rebuilding my NP208 and I have it torn down with the exception of the two blind bearings, one in the case and the other in the shaft. I don't have a pilot bearing puller or blind bearing puller (I did ordered one off Amazon but it got lost apparently)
The case has been given me a rough time... I have pulled the rollers and fabricated a makeshift tool I thought for sure would do the trick, some 1/8" plate drilled for a 5/16" threaded rod and a 2" PVC channel to leverage on the case. I thought all was going as planned and then it popped free only to realize it broke the top of the race. I tried it again after heating up the case on the BBQ to about 400f thinking the race would either fall out or need a LITTLE coaxing and I snapped the other half of the race...at this point I think I'm Dremel bound (someone said to cut it in three parts and it will be easy t collapse?) but one other thing I saw was to weld a bead around the race and it would cool and pull it away from the case. Can you do this with a wire feed welder?
Would dry ice be of any benefit here?
Haven't tried the shaft yet but I'm guessing its going to be the same...?
