non a/c conversion
dee123
ontario
derek
k20
I can see that the blower housings are different between a/c and non a/c. Are the heater boxes the same? if not, it could still be used, right?
J Knight
Baytown TX
82 Chevy
350ci
Fire wall is different between a/c and non a/c trucks.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Oh...Well, you said heater box and i thought outside.
I know greazerpuppy posted pics from his gm books of the underdash parts.
J Knight
Baytown TX
82 Chevy
350ci
Are you wanting to convert your a/c truck to a non a/c truck? If so you are going to need a cut out of a fire wall section of a non a/c truck and graft it to your fire wall, then you will need the inner unit, control unit, and outer fire wall fan/air duct for the convesion to all fit.
dee123
ontario
derek
k20
thats what i figured. i'll weld a panel over the a/c hole. just wanted to make sure heater boxes are different.
Fell free to take plenty of pics and do a write up, this isn't somethjing you see much of and see it get asked about a lot in here lately. :waytogo:
dee123
ontario
derek
k20
by the way, i mentioned on another thread that i work for a FORD dealer. we have a windstar recall involving reinforcement brackets and adhesive on the front subframe. the adhesive works really well as an alternative to welding for small repairs. i fixed a hole in my floor with it and once dried it is as hard as steel. pounded on it with a hammer and it didn't cracked or break. 3m makes body panel adhesive. it is basically the same thing. makes things much easier.
dee123
ontario
derek
k20
a couple sheet metal screws too of course
... 3m makes body panel adhesive. it is basically the same thing. makes things much easier.
I've been using that stuff on quarter panels for years, never thought to use it on floor repairs. That's a really simple, but really good idea:)
dee123
ontario
derek
k20
thanks. going to use on rockers (with screws) and on my trans hump when i swap it.
dee123
ontario
derek
k20
found a non a/c blower housing, heater box, control unit and under dash wiring harness for $50. let you know how it goes. won't start till after next weekend.
Hard
