No check engine light.
Jetstarrfire65
Colorado
James
Anyone have some ideas on no check engine light? We been having issues with to much fuel loading this up? Went and bought an obd 1 code reader and found out check engine light doesn't come on at all! And ideas how to fix this problem? Could it be as sim0le as a burnt bulb? Or something more? Any help would appreciate it !
fast 99
Spokane, Washington
should come on and go off when key is turned on, bulb check.
If that doesn't happen next move is check bulb.
Yes it could be a burnt bulb,a broken wire,a cut wire,a blown fuse, which p.s. a blown fuse is never just a blown fuse it blew because it was doing its job and will blow again unless you find the real problem. What are you working on?
hoagster
California
K10, 1500
5.3l
From what I understand and I could be wrong it has to be a filament bulb, leds wont work. So if you went digital the check engine light still needs to be filament.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Try and Unplug temperature sensor on intake manifold by water-neck/thermostat housing and see how it acts then. Also clean grounds on neck bolt/stud.
86sunnyguy
