New Speedometer Question
elimin8tor65
Barry
Im in need of a new speedometer. The one Im looking at buying says its the one Im gonna need. The only issue im not sure about is where it says "Speedometer 0-85 MPH W/O Speed Sensor Chevrolet C10 1981-1987". What is a speed sensor with regard to my speedometer needed for? All im doing is replacing the gauge. My old one worked fine, I just broke the needle and also want a newer looking gauge. Do I really need a new speed sensor? Thanks​
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I know on the squares that use TBI, there is a speed sensor that relayed the vehicle speed to the computer. If your truck has a carb instead of a TBI, its a pretty good bet you won't need to worry about the speed sensor.
Zelph
Nevada
Should be a little green box mounted behind the cluster.
Gander
Army
Dirty Bay, TX
Lawrence
VSS was on the back of the speedo for at least a couple of years before the 1987 TBI squarebodies. I think back then it was pretty much just a speed sensor for cruise control but not sure. Pretty sure it was on there back of the speedo for at least a couple of years prior to the 1987 TBI trucks
ali_c20
Austria
Alexander
C20, K5
VSS is connected to the ECM and gives input needed for fuel, EGR, torque converter lockup and other things afaik.
Speedos with VSS and VSS buffers are available online.
WesN
Edmonton Alberta Canada
Wes
C1500
1981-1983 use a mechanical/electric resumeable cruise control with speedo cable in and out. 1984 and up use an electronic cruise control which would require a VSS tied in with no speedo cables attached to the cruise control.
duncan_schawalder
