new owner from AL
prattville al
nathan
hey yall im nate i just got a 1979 k10 scottsdale with a 400sbc. been trying to identify everything on it so far i got 400sb th400 tansmission. i believe the rear diff is a gm 12 bolt. the front i cant tell if its a dana 44 or gm 10 bolt. its hard to find any numbers even though ive been scrubbing and spraying brake cleaner. any info or tips? thanks?
Lugnut
Northwest Georgia
Jason
'79) 350/ granny 4-speed, '86) 350/A833 3-speed with overdrive
If it is a Dana,look for a 44 casted into the housing. Next to the inspection plate.
Sent from my ADR6350 using Tapatalk 2
prattville al
nathan
i crawled under the truck and on the of the diff i saw gm 4 on the rear axle looking at it from the back of the truck after some scrubbing i saw EST on the right side. have no clue what it means
:welcome:
Howdy! '79 probably came with a 10 bolt when it was new, they have a fairly round diff cover.
:welcome: from N.E. Texas!
Joshua8336
Dirty South AL
Joshua
Big welcome from ANDALUSIA ALABAMA. glad to have another Alabamian on here.
Welcome to GMSB Nate. Jump in where you can. We're here to help. :handshake:
attachment.php
prattville al
nathan
Thank you!! I do have a lot of questions regarding my 400. Mainly being about the oil leak
Joshua8336
Dirty South AL
Joshua
redo the rear main seals, front main seals and pan gasket. if it's still leaking change the valve cover gasket.
John81287
Mchenry,IL
V20
Twistedwhisky
