New fuel tank
Houston Ben
Houston
Ben
Hi all, Don't know if i'm in the right section here but I want to replace the side mount tanks on an 86 c10 with a center tank but use the same fuel door, is this possible? If so, anyone know of a tank that will do this?
Thanks,
Ben
bigcountryguy19
Sealy texas
josh
6.2 diesel
Anything is possible lol might have to notch the frame and make a custom fill pipe to go over the frame and to the stock fuel door. Just curious? What is your reasoning for trying to do this? And are you talking about putting in a rear tank between the frame like a burb? Or using a tank in the middle of the truck?
Not to mention driveshaft and exhaust under that area
Houston Ben
Houston
Ben
Sorry guys, guess I was kinda vague, it was late. I have an 86 SWB c10 that I plan on swapping a 2011 or newer 5.3 with transmission into it. Could I use the stock fuel tanks? I was told I probably need to get a new tank but I have never done this and don't know. I would like to go middle of truck but I think 89Sub is right on the money with the drive shaft and exhaust. I think if I put it where the spare tire goes I wouldn't be able to use the stock fuel doors. IDK???? Any insight would be much appreciated. By the way, I have no problem using the stock side tanks just don't know if they would work due to the new fuel system I would have to put in.
Thanks!
Boone83K10
Boone, NC
Benjamin
They probably meant that you need a gas tank with a sump for the 5.3L. Just buy an 87 TBI gas tank (which has a sump) and put the correct sending unit/fuel pump in and eliminate the mechanical pump you probably have.
while you're at it just make it DUAL tanks!!!!
dmcelhan
