New Clutch Not Engaging HELP
7879Chevy
Ohio
Alex
78 Chevy c10 Custom Deluxe 79 Chevy K20 Cheyane
Both have 350sbc
Just bought a 1979 Chevy k20, dropped a new 350sbc in it I rebuilt. The trans is a 3 speed with low gear, and the clutch is non hydrolic so its all linkage. The clutch was brand new I installed, on a new flyweel.
The problem is the clutch when I push the pedal does not seem to really engage, the fork only moves maybe a half inch when pedal is pushed and then the cab actually moves as the clutch is pushed.
The gears grind and do not go into gear because the clutch doesn't seem to engage. The linkage is tight, I honestly do not know where to start diagnosing. If anyone has any ideas or advise would be greatly appreciated.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Wrong or bad throw out bearing?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
I would look at the z-bar setup, it sounds like the rod going from the pedal through the floor is hitting something or the z-bar isn't installed correctly.
Or possibly the clutch disc is installed backwards?
highdesertrange
kalifornia
mike
k30
what do you mean the "cab is moving"? how much free play do you have? highdesertranger
mick84
