Needing some help guys wiper switch wiring!!
jameslee
Saskatchewan
Chad
Alright I'll start off by stating the obvious here haha new to the group so I'll apologize for any technical difficulties i may have using the forum.
The issue I'm all jammed up on here is I'm swapping an 87 cab onto my 82 chassis and want to run the 87 column with wiper switch but the wiring kit i ordered has the wrong style plug to match up to the pulse control module. anyone here know what the designation of each wire is for control module on harness side??? my harness has each wire coded dash light wiper hi wiper lo ground etc. just need to know which wire has to go on which terminal for the control module.
Thanks in advance appreciate it!! Ill get some pics up as soon as i have a minute to figure out how
chengny
Do you have the harness side connector still on the module (with the leads clipped off)? Or do you just have the module with nothing connected on the harness side?
jameslee
Saskatchewan
Chad
I have the whole harness I pulled out of it when I stripped the cab for paint. So the lead is there yep. Module is still hanging on the column.
jameslee
Saskatchewan
Chad
Here's where it's at. I've got the wiring all laid out on the bench double checking things before it's in there and I need to make a bunch of mods.
jameslee
Saskatchewan
Chad
Inside shot
Looks good.
Snips71
