TubeTruck
- Sep 4, 2019
- East TN
- Denis
- Suburban K10
- LQ9
So as the temps have been dropping here in Chicagoland my truck is finding it hard to stay running. On a decent day I come out in the morning, step on the gas pedal once, fire it up and it stays running. High idle is usually around 1k rpm, by ear (I don't have a tach, that will happen when it warms up a bit). Lately though that hasn't been the case. As the temps have been hovering around 0 it's been hard keeping the truck running unless I keep my foot on the gas. It starts ok, then you can hear the rpms drop slowly until it sounds like a thumper cam, then stalls. Now I have to crank and feather the gas to get it to start which kicks down the high idle. It had a tune up this past summer so I don't think that's much of an issue but I do know the engine needs a rebuild. It's got a Holley 650cfm spreadbore on it with an electric choke, performer intake with the heat crossover active and a 1/4" thick gasket under the carb. I'm thinking about raising the idle setscrew so it idles higher but that just seems like a bandaid to me. Should I raise the idle higher? What else can I do to help it?
