need help from someone who has painted their vehicle.
1981scottsdale
Edmonton
devin
Scottsdale
Just wanting to see who has painted there own vehicle and wheather they have had sucess or not.
robert8096
Goose Creek SC
Robert
Painted the cab forward including the door jambs on mine in my garage. Used single stage Kirker paint.
What I started with.
During
Finished for now.
1981scottsdale
Edmonton
devin
Scottsdale
That looks great! What did you paint it with? If gun what was your ratio for thinner and paint. Did youbputbin hardener
robert8096
Goose Creek SC
Robert
I used this gun setup. http://www.tcpglobal.com/spraygundepot/tcpgate.aspx
The 1.8 for primer and the 1.4 for the top coat. I used the paint manufactures suggested mix ratio of harder,reducer and paint. Reducers are based on outside air temp, a good auto paint supplier in your area will be able to help you pick the correct reducer.
great info here!! I'm starting to look into this kinda thing as well. I'd LOVE to learn how to paint a vehicle and may play with this on my Caprice :)
1981scottsdale
Edmonton
devin
Scottsdale
Awesome thanks so much for the info ill peobably have more questions as they come by
Right now I have this set 359 $ marked down to 89 and I got it for 45 so a great find I think!
^^^WOW!! how did you get that big of a discount???
84k20
Coventry Rhode Island
Brandon
need help from someone who has painted there vehicle.
I'm very interested in this as I will need to paint my truck as well as soon as it gets a little warmer!
1981scottsdale
Edmonton
devin
Scottsdale
I love when people screw up :) they had it on sale from 349 to to 149 them my buddy talked them down to 89 and just as he was about to buy I told them ill buy one if theyll beat his price and bam 49.99 then I got some rustolem water based primer which ive heard is really good and ib payed 30 $ fpr 2 gallons. Now I just to decide if I wanna dish out money for car paint or just use fire red rustolem. For my first paint job.
86chevyk20
Buffalo
Liam
here is my k20 i painted last spring, but i am painting it again when it gets warmr because i am not happy with it. i want it nicer :)
86chevyk20
Buffalo
Liam
just a few more pics. It looks good in the picture but it isnt what i want
robert8096
Goose Creek SC
Robert
I would suggest that you practice on some old body panels and use the cheap Dupli-Color Paint shop paint. Start out with the solid colors and progress thru the metallic and candys. http://www.duplicolor.com/products/psFinishSystem/
Good score on the kit.
I have about 200.00 in paint and supplies in my cab forward paint job. Most of the cost for a paint job (unless you are going to use top of the line paint like HOK) is going to be in supplies like sandpaper, tact rags, guide coat spray, silicon and grease remover etc. You will need this stuff even if using Rust-Oleum. Hours of prep work is what turns out a good paint job. Then the great fun (and nerve racking) of wet sanding and buffing the finished product.
Keep in mind that if you go with a Rust-Oleum paint job then decide later to switch to car based paint all the Rust-Oleum stuff will need to be removed.
If you do decide on Rust-Oleum here is a good site that has info on rolling it on as well as spraying via a paint gun. It tells you how much to thin it as well as what to thin it with.
http://rolledon.forummotion.com/
My other on-going and expensive paint project.
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
Back when I was going to college I was a co-op student which meant I alternated between work and school every quarter. Anyway, I took auto body classes a the local vo-tech school at night during my work quarters since I had nothing I had to do at night. It wasn't really a class as much as a place to work on projects with an instuctor around to provide guidance. I painted my car and a buddies 72 Burb. It was fairly cheap and they had all the equipment and a paint booth. I just had to supply my own primer and paint. Might be worth checking into, having a booth made a big difference in getting a nice clean job without having to buff out any dirt.
Now that I think of it that has been about 20 years ago. I'm starting to feel old.
paz4x4
