Need: 1976 Chevy K20 Emission Label (or pic of yours)
legend57
San Jose, CA
Rob
I need an emissions label for a 1976 Chevy K20 with;
400 cu. in. engine
California HD Emissions (has AIR, EVAP, PCV. Does not have EGR or CATS)
I've searched everywhere, including Classic Industries and LMC, and haven't found the label. If someone has one on their truck, please provide a pic.
Thank you
400 cu. in. engine
Thank you
Have you searched our forumn? We have a dedicated thread to this.
Pic of the page you are looking for. I can't seem to link to it
legend57
San Jose, CA
Rob
Thanks for pointing me to that thread. Definitely worthwhile to compile as a library for other members. If I'm able to get a pic of the one I need, I'll be sure to add it.
76Big10
California
Tim
Did you ever find pics of the labels you needed? I have a 76 Big-10 that has HD California emissions so I’m looking for the same stickers you are. I have found them on this forum yet so let me know if you find what you need!
legend57
San Jose, CA
Rob
I haven't. I've looked through the forum as well and haven't found one with my combination. I may have found a truck that has this combination and I'm going to see if the owner could get me some pictures of the labels. If successful, I'll pass them along.
76Big10
California
Tim
That would be great! Thanks.
76Big10
California
Tim
Hi, legend57! Checking in to see if you have any updates on locating a VECI label for your truck.
legend57
San Jose, CA
Rob
I'm still waiting to get the pictures. I'll ping them again.
If I am successful in getting the pictures, I'm hoping to work with the current label supplier to get one made that matches the picture I provide to them. This will likely be a lengthy process, but at least an option to finally get the correct labels.
76Big10
California
Tim
Awesome! That is my plan as well.
76Big10
California
Tim
While we wait for the photos of the stickers, would you be willing to share some pics of how your vacuum lines are setup? I’m going in blind and would love to have an idea of how this thing should be setup. I’m especially interested in how the smog pump valve is connected to vacuum. Thanks!
legend57
San Jose, CA
Rob
Here is a diagram from the Factory Shop Manual that I'm following. The diverter valve is connected to a port on the Qjet just behind the choke pull-off valve, and tees into the bottom port on the thermal (spark control) switch on the water neck. Note, there is also a port that goes to the switch in the air cleaner.
I haven't fully rationalized why it is set up this way, but here is my understanding so far;
- The vacuum port on the diverter valve has a constant leak. It takes quite a bit of vacuum in order for it to trigger. This constant leak needs to be factored in when you're tuning the carb.
- It is my understanding that when there is very high vacuum (deceleration at higher rpm), the diverter valve closes, and the flow of air into the exhaust stops, to prevent backfiring.
- The thermal switch on the water neck activates when the engine temp gets too high, which opens the bottom port on the switch, and also activates the diverter valve. This is to stop the flow of air into the exhaust, reducing temperatures.
Since I'm still building the truck, I don't have this fully set up yet, but it is getting close. I'll take some pics and upload in the next day or so.
76Big10
California
Tim
Wow! The vacuum lines for the 400 are quite different than the 350! Does your manual have a diagram for the 350 with cal emission?
I think you are on to something tho with the diverter valve controlling when the air is introduced into the manifolds.
76Big10
California
Tim
Found it!
FenderBanger
