Nasty Noise Coming From Flexplate/Converter area
AKguy
Alaska
Randy
K30 Crew Cab Silverado
1985 K20 Suburban, 350/700R4, 14” 168 tooth flexplate, three bolt converter. When warm/hot, about 90 here today, getting fairly loud, tinny/grinding noise while parked and in motion. Looked at starter intereference, none I could fine, put different starter on, no change. Truck is shifting as it should, fluids are up, no visible leaks, no visible cracks in the flexplate, converter is torqued. New one on me.
AKguy
Alaska
Randy
Just saw 1987 Jimmy’s similiar post and it sure sounds like cracked flexplate!
Memaloose
Dolan Springs, AZ
Tony
On my '79 Silverado K20 with a small block 400, the welded balance weight on the flex plate came loose and made a racket like you describe. I don't know if yours is externally balanced but it's one more thing to look at.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
I had a funny noise at idle in my Camaro that I could hear when parked next to another car.
IIRC, the converter was failing- 2800 stalll Vigilante. The mechanics discovered that post mortem when the tranny bit the dust at 60MPH.
So, point being, a case where it is worth getting it looked at now while the fix may be cheaper...
And, hoping I am wrong about your rig.
:burnout:
AKguy
Alaska
Randy
Mechanic just told me the flexplate is fine, going to replace the converter. Stand by for more.
AKguy
Alaska
Randy
Converter, B-29, replaced, drives fine, no noise. Just in time as I am headed home (flying) to the frozen north in a few days.
AKguy
Alaska
Randy
Belongs to family in NM. Hood has been replaced since pic was taken.
squareton
topeka ks
chris
k2500 suburban
looks great! what height lift is that? springs only?
AKguy
Alaska
Randy
Springs on the front, leveler blocks in the back.
Squirrely Brother
Dallas, TX
Alan
My flex plate looked just fine until I unbolted it and every bolt hole was cracked. I thought it might be the converter, but was glad it ended up being a $33 part with 3 hours work to fix it. I hope your mechanic’s mistaken.
80BrownK10
Greenwood, SC
Nate
I think he fixed it if I remember reading the last post right. Was a bad converter.
Stickman
