Mystery wire
87ChevyR10
Kansas
NA
NA
NA
So, I was poking around the engine bay and found a single wire not connected to anything. It is coming off the harness at the front clip where the headlight wiring is on driver side. It has a weather boot and the wire is pink and white.
Any ideas? Thanks.
Georgeb
Wisconsin
George
K10 Burb Z71
For the brake proportioning valve on the feont cross member.
87ChevyR10
Kansas
NA
NA
NA
Well, that would explain why the front pulls to the right when I apply the brakes. Where exactly does it plug in at?
Thx!
Edit: I got it!
Georgeb
Wisconsin
George
K10 Burb Z71
Thx!
Edit: I got it!
That will have no effect on why it pulls. There is a brake or alignment issue causing that.
87ChevyR10
Kansas
NA
NA
NA
Oh, bummer. It seemed to have lessened the severity of the pull.
Georgeb
Wisconsin
George
K10 Burb Z71
That wire turns the brake warning lamp on when the spool in the proportining valve travels too far one way or another in the event of a brake failure.
86 Square Body
