Mystery Vacuum line
Jason Ramirez
Los Angles
Jason
K1500
5.0 4wd
Help! I was putting new spark plug wires on and I must have popped this off and I cannot seem to locate where this goes. One end goes into the vacuum reservoir and the other line has this tee then check valve and then to the mainifold. Any ideas of what hooks into this? It’s make a sucking vacuum sound now.
1985 gmc k1500 305 1/2 ton caborsgee.
WFO
Texas Panhandle
It goes to the firewall, up by the air conditioner, to operate the heat/defrost door.
Jason Ramirez
Los Angles
Jason
K1500
5.0 4wd
Thank you! I’ll look for thr connection to/through the firewall.
Cheers!
nathan27
