My v-belt to serpentine belt conversion
FresnoK5er
FRESNO,CALIFORNIA
I did this last spring. It's perfect setup for my high output stereo. No more belt slippage.
**** yeah! :popcorn:
Was that a kit? What was the damage for it?
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Dude wholly ****, that is nice.
That's a great set up. I'd only have one problem with that. But sometimes you have to sacrifice something to have the best of the rest. Kinda took a hit in the AC compressor department. Hopefully they've gotten better, but those pancake style AC compressor are not near the quality of what you took off in most cases. I do like the mounting and size of the pancake comprssor though. I hated working on cars that had that big ass compressor on them, but they worked great.
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Hell yeah!
I've been wanting to do this
I think I need to start pimpin myself to the fat laides. I need some cash. This place is starting to wear on me with all my ideas I get from here, and not enough cash to do it. Now I wanna go with an LS motor and -E trans in a square. And my collection of parts is all old shcool. I'm still not giving up on my 68 Olds 455 and Variable Pitch stall TH400 though. That one is gonna happen.
FresnoK5er
FRESNO,CALIFORNIA
I haven't hooked up the a/c yet. I need to find the adapter fittings to the compressor and get the system charged.
Next up is to replace the broken center bolt (tie bolt) on my rear leaf spring. It broke and my springs moved some and I lost my pinion angle shim on the drivers side. I wondered why when I let off the gas my truck got squirrely, lol (not really funny though). I am also adding some traction bars that won't limit the rear suspension up/down travel, at least not that much. Waiting on parts right now.
Can't wait to see those running bars mounted what she looks like. :High 5:
Cool. No hurry for the AC in Cali anyway. I can tolerate Cali heat cuz its drier. Its the freakin humidity here that after 80, I need AC. I can go with 110 in AZ or Cali wo AC no problem with a window down.
85k10383
Glengary, WV
Ross
K10 Scottsdale
Did you buy that as a kit or did you have to source all the parts individualy? What did it set you back if I may ask? I would love to go that route, just without AC.
FresnoK5er
FRESNO,CALIFORNIA
It was about 850.00 for the kit. I purchased it through Summit. Of course the kit without a/c will be less expensive though. It would be a pain to find everything new yourself but you would probably save some $$. I wouldn't purchase anything but brackets and such from a wrecking yard. Not worth putting worn out parts on the front of your engine.
http://www.summitracing.com/parts/NAL-12497698/
oneluckypops
Sedalia, Mo.
Luke
What would bewrong with using a Serpentine set up from a 96-98 Vortec?
Did the power steering pump already mounted to the bracket? Was there a bolt behind the pump to mount the bracket, like this?
attachment.php
DamnTexan77
