My truck is dieseling
OrangeC20
Walla walla
Reuben
So after my truck gets warm and I drive it a while, I shut it off and it tries to continue running. I know it has to do with the timing but not sure if I need to advance or retard the timing.
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
typically, your idle speed may be too high and/or your timing may be advanced a little too much. start with your idle speed.
LACROMER
New Bern, NC
Lacy
5.7L 350
What type of fuel pump do you have? I used to run a Holley red electric and it would diesel all the time, if you are running any electrical fuel pump you have to have a fuel pressure regulator regulating the pressure to what is recommended for your carb.
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
Mine was doing same thing i replaced header gaskets and carb gaskets . Had gas on intake and you could hear the valves through exhaust. No more running on after its off. Sounds alot better too
Scrambler-Cafe
