More HP or lower gears?
Joe383
Moses Lake
Joseph
"However, good heads (with 170-180 cc intake runners) and a mild roller cam can give your 350 the best of both worlds."
I would rather have heads that were a little too large over a cam that was a little to large though. 400HP takes a lot of cam or a lot of head. You would need a cam with about 240* duration at 0.050 with a 170cc head and would be spinning the motor around 6,500K The larger heads would allow same power at lower RPM with less duration. Good example of this is GM ZZ5 crate motor compared to say the Edelbrock performer RPM. About same rated HP and torque but I bet the ZZ5 is a was smoother motor with a lot more low end torque.
TheBeast80
New York
That's a good idea, I might put in a limited slip for the rear
TheBeast80
New York
I was just looking at one on eBay for 540? Any suggestions on brand of gears?
Moderator Administrator
DAMN !!! Nice truck though. :manos: Don't worry, that stuff wipes right off and adds a little shine. I'm sure I wasn't the first.
Yep, if you're attached to the 700r4, and doing a gear swap, get your money's worth and go at least 5.13's maybe 5.38's since you're running such a tall tire. That'll take alot of stress off the 700r4 and get you moving much easier.
If you're running a 14b Full Floater in the rear, keep in mind, 4.56 and higher numerically, you'll have to buy a carrier too, since cut off is 4.10/4.56. Now my might find some aftermarket thick gears that will allow use of the 4.10 and down carrier.
TheBeast80
New York
It's a 14 bolt semi float not the full floater. Do I need to work about a carrier with that axle?
I won't swear to it, maybe someone else can confirm, but I've not heard of this axle having a cut off. I think the same carrier will work with all gear ratios.
68post
Indianapolis
Tim
454, TBD
HotRod you are correct, ( I double checked at "Tom's Differentials" ).
TheBeast80
New York
Great, is that the same for the corp 10 bolt?
TheBeast80
New York
Alright, so I will need to get a new carrier for the 10 bolt? I'm just trying to figure out whether I need to order for these 4.88 gears
68post
Indianapolis
Tim
454, TBD
No, not the same !
Sorry, let me clarify. For the 8.5"/8.6" corporate 10 bolt.
If your original carrier is for a 2.41 or 2.56 gear ratio - then you'll need a new carrier for a different ratio than those two gears.
If your original carrier is for a gear ratio of 2.73 or numerically higher ratio, ( 3.08, 3.23, 3.42, 3.73, 4.10, etc..), you are ok.
2 series or 3 series carriers.
( I have a set of new 5.57 gears - if you really want to gear it down :Insane: )
jmbcary44
NC
Jon
v1500 Suburban
5.7L 350 SBC
and post up pics on whatever you do!:popcorn:
Driver4r
Nebraska
Trevor
k10,c20
dont agree.... The bigger the heads on a smaller engine, the more you have to spin it to make power..... you can only shove so much air in a set space.
Bigger runners make an engine a dog if its not built to handle the air you are trying to shove in it.
But when i say big runner, im talking 200+ on a 350. You dont need a 210CC runner on a stock engine with an RV cam.
Now if i build an engine with alot of overlap 320ADV Dur.. theres alot that gets lost thrue the exhaust, so i need to move that much more air.
TheBeast80
New York
I have 4.10 gears now so it sounds like I can just buy the gears, I'll take pics of everything bf and after install
crowe-t
