Mechanical or Electric Fuel Pump.... Thoughts?
Moose Drool
Southern Oregon
K1500
I have been toying with the idea of upgrading my carb fuel system with an adjustable fuel pressure regulator with a return line back to the fuel tank. Should I keep the mechanical fuel pump, or go with an electric?
Anyone do the same type of system? Thoughts?
yevgenievich
Place
Name
Year
Model
Size
Have both, electric is nicer if vehicle sits often. But then cranking engine to get fuel also pumps oil when starting after sitting for a while. Really should add ignition/oil pressure driven electric fuel pump circuit if daily driver
75gmck25
Northern Virginia
Bruce
Either pump works fine for a carburetor and will provide plenty of fuel. If you want add a pressure regulator, using a mechanical pump means you have to figure out where you want to put the hardware.
GM originally had hard fuel line from the pump running up behind the alternator and directly to the carburetor, so it all tucked right under the air cleaner. Fitting in a good filter and regulator takes more space. With an electric pump you could mount it all off to one side or down low, and just run the fuel line over to the carburetor.
Bruce
SquareRoot
I guess you wouldn't want fuel injection then huh?
ali_c20
Austria
Alexander
C20, K5
I run a fuel pressure regulator w/o return line next to the carb with mechanical fuel pump with a return line. Works great and everything sits under the air cleaner.
Loco Hills
K-30
Or just get a mechanical pump that does high volume,low pressure.Check it at installation for proper pressure and drive on
nujac
texas hill country
bruce
k20
I installed both and here is why. If your truck is not a daily driver the new ETHANOL GAS will not be in the fuel bowl when your try to start it. I run the electric fuel pump to fill the bowl for about 30 seconds before I start cranking the engine. Now that they have the NON-ETHANOL GAS right by my house I no longer run the electric fuel pump at all unless the truck has sat for a couple of weeks. I added the electric fuel pump about 10 years ago. No regulator used being the pump was designed for a carb and not fuel injection. If you use your truck off road I seen where a regulator that you can turn down for trail use is helpful to prevent flooding.
Moose Drool
Southern Oregon
K1500
That is exactly what I am experiencing.... no fuel in the bowl. It takes pressing the pedal to the floor to get it going.
BillK
Waldorf Md
Bill
Blazer
Unless you have a crazy engine there really is no need for an electric pump or a regulator. Just one more thing to go wrong.
When I had my 85 K-5 Blazer I pulled the 305 out and built a pretty nice 355 for it. I used the same pump and Q-jet that were on the 305 and never had a single issue with fuel.
BillK
Waldorf Md
Bill
Blazer
If you are having to hold it to the floor to get it to start that sounds more like it is flooding. Too much fuel.
If it really is no fuel in the bowl try cranking it for about ten seconds, then pump the gas twice and try again. It should start up. My 84 S-10 is carbureted and it will sometimes sit for a week but it still starts right up if I use that procedure. Same with my Wife's 84 Riviera
59840Surfer
Montana
Joe
Make sure the choke works correctly - a lost art - and I use electric chokes with a vacuum choke break on my Q-Jet.
I put my electric pump back at the tank to push the fuel - which is the best way to move gas without running the vapor pressure so low that it can vapor lock on a hot day or sitting in traffic.
I've had that running for over 20 years that way.
Raider L
Shreveport, LA
William
@Moose Drool,
So what is it where you have to pump the pedal to get what going? Are you talking about a situation where the engine is not running? It died and you're trying to restart? So how does the bowl get empty if the, what, the electric pump is not going....? Explain all that again. I don't 4 wheel so I'm sure there's stuff I don't know about but it's interesting, what is it?
Hard
