MACHINING 16.5" DOWN TO 16"?
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
The angle of the bead lip is what the old tire guy told me. Though if I recall the diameter of the wheels are the same. The tires were givin the .5 so to know they had the odd ball bead, 16.5, 22.5,
This is true. 16s and 16.5s are the same outside widths, but the inside lip is thicker/wider.
Found that out the hard way. I accidentally put a 16 tire on a 16.5 rim once.... once...
I fought and fought to get it on, then i pumped it up to 90psi bounced it and hit it, trying to get it to seat. Even dropped it from the upstairs loft at work. Got the back side of the bead to mount, couldnt get the front to go. Finally gave up on it. That tire and rim are forever 1 now though. Even had a tire shop try to get it off, no luck.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
One of the job shops I worked had a lathe set up for wheels. Guys would bring in those old magnesium wheels, all pocked and pitted. They would sand blast the kidney or slot area, paint it, bring it to us. Four jaw chuck with aluminum soft jaws, mount in chuck, dial od, and runout to as close to zero as the wheel would allow. Used a 1" HSS (high speed steel,) tool stick out about 4" at usually a 45 degree angle. Just an eyeball thing so as you were cutting the wheel, only the tip would cut, and the shank would not hit, for example the tire bead area on it's way out in the cut....Anyway.. grind lots of clearance on the cutting edge side, W/1/8" radius which was necessary for the fillets, and to leave a smooth finish. Lathe speed around 45 rpm. Starting in the center and work out, for better finishes. touch the face. From there go in .010. Using the good old fashioned "two handed it" way on the Y and Z axis, an acquired skill, until you had faced the whole wheel contour. They looked better than new, very smooth finish.
I have a sweet set of 16.5 X10" aluminum wheels, if I could machine them down, I sure would.....but believe me, for those wheels, hang em' in the shop and toast them on occasion.
Dooley
North Coast
RW
V30
Wheels used on highways have to be DOT approved. Anytime you modify a DOT wheel it loses it's approval.
Someone hits me with unapproved wheels I'll sue his rear off for operating unsafe vehicle.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Not worth the squeeze. Or the lawsuit.
I have a set of steel 16.5 destined for scrap unless someone wants to get them for free.
Bennyt
Surprise
Ben
Similar issue with 5th wheels. I really want a small toy hauler which is hard to find and salesman kept showing me 3 axle stuff. I mentioned my truck was a '90 and the truck is rated for up to 13k. A lot of the toy haulers are way over that when loaded and he has heard of insurance not paying out claims on trailers that were overweight.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
This is interesting, because I have a set of 8 lug aluminum slot mags that are 16.5 x 10(or something like that, they're not where I can look at them easily in the near future). I've been told that 16.5 tires are expensive and not very many companies make/sell them. Dad bought them 25 years ago when the 16.5 was the go to tire for 3/4 and one ton trucks.
Sounds like I find someone who really wants old school looks and doesn't mind spendy tires, or I find something to do with them in my building. Don't wanna scrap them if I don't have to....
Moderator
Yeah, definitely don't scrap them.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
I need to get pictures of them, and better descriptions. My building is bit of a mess at the moment; no lights and hot weather aren't conducive to organizing.
NateP350
