Ls swap over $6000?
Jarhead79
Mt Vernon il
Michael
Does this not seem a bit too high? Not including price of the motor and computer. Most of their prices seem high but are name branded stuff so I can see it being near this much for all brand new stuff! I certainly think most of this can be bought cheaper or even slightly used.
Moderator Administrator
Doesn't surprise me considering half that is the labor costs of a shop.
dougbert
5535 feet in Utah Mountains
doug
K1500/nv4500/np241c/33x12.50x16/4.10 Gears 14BFF
5.3L - 2002 Silverado, rebuilt top end, long tube headers
good price
a bud here charges $10,000 including engine at $50/hr
oops: including engine, harness, etc
Jarhead79
Mt Vernon il
Michael
for all the work and new parts I guess it's not that pricey, I'm sure there is other little stuff I'm sure that'll pop up, I can get a motor and computer and stock harness for $600, hard to believe a harness new is $750/$800 dollars though.
yevgenievich
Place
Name
Year
Model
Size
$750 for a custom fit harness is about right. I just paid $700 for one with factory sryle wiring spliced in and plug in bulkhead connector simply because I am running out of time on mdifying another one my self. Over all prices look to be reasonable for exception of motor mounts.
Jarhead79
Mt Vernon il
Michael
I just wish I had an enclosed garage and some tools, I can get better prices on a lot of this stuff through my part time job, and would save a ton on labor doing it myself, might see about getting most everything in the truck and routed and ask them what it'd be if I had them do the plumbing etc
yevgenievich
Place
Name
Year
Model
Size
If you have the time, the swap can be done cheaply. I have done two swaps before when time was available modifying the harness my self. My ls1/4l60e was total for $3500(6 years ago) and 5.3/4l60e was around $1500.Both swaps were done in an apartment parking lot.
I got a lot of things acomplished being a broke college staudent.
Jarhead79
Mt Vernon il
Michael
I'm not the most efficient mechanic but I'm capable of doing it I'm sure, but I was in the $3000 ball park range if I wanted to just do a stock swap, the guy with the motor is including the harness and ecm, and I know a guy to clear the vats system, and can get a tune for less than $200. I may end up attempting it this summer, just need to start ordering the little semi essential parts, only thing I'm not sure about is how to set this up use my 350th, was told I can use it and it's in good shape, never been abused, and shifts firm, I've read about a few doing this and thought why spend the cash on a trans if I have one or two available for nothing.
yevgenievich
Place
Name
Year
Model
Size
Th350 will bolt up using a pilot spacer on the end of the torque converter and possibly ovaling the mounting holes on the flex plate a bit. Definately should be ablke to get it done for $3000 doing most if the wor your self. Tbi fuel tank with upgraded fuel pump would supply enough fuel and can yse corvette fuel filter for a fuel pressure regulator.
dougbert
doug
I am installing a 5.3L into a 1984 GMC K1500. I am renewing the K1500 as well. Below is what I have spent for the major systems of the truck:
actual truck, $750. No engine but had a SM465 and NP208 - but I wanted a NV4500 - used 2002 silverado 5.3L engine 144k, with accessories: $700
(note on engine: I found 2 cylinders filled oil, oil in intake. I think this was upside down for awhile)
truck upgrades/fixes/repairs, including wheels, tires battery shocks, Tie rod ends, paint, etc: $2500
More Steering parts, etc: $200
Fuel tank, AN fittings, hose, fuel pick up and fuel pump, tank support parts: $550
Used NV4500, NP241c, pressure plate, power train other then engine: $1350
Basic engine parts other than engine, ARP bolts, etc: $450
Engine renewal, new LS2 cam chain, sprockets, O2 sensors, gaskets, lifters, whole top and front end to all new parts, etc: $1590
Exhaust system, Schoenfeld longtube headers, muffler, V clamps, $550
862 heads reworked, Comp Cams dual springs with .675 lift capable: $865
Total cost OF PARTS ONLY of above: $9,458
no labor in there, I did 99% of the work
LS HOWTO BOOKs, and tools, lots of LS tools,etc: $954
NV4500 tools: $457
Debating to go for the minimal tranny rebuild kits at $300 or the full kit at $800 (has 9 syncros)
for the full parts breakdown on Dropbox see the following link, which includes part numbers and where I found the cheapest at the time. I think I have captures 95% of the parts cost. Misc autoparts purchases for shop supplies, etc are not all there:
https://www.dropbox.com/s/0ez9aclwtalh4u9/K1500 5.3L Build parts cost as of 1 jan 2016.xls?dl=0
wish there was a way to upload that file to this post so that the post does not have to reply on my dropbox account being valid forever
link to build in sig
dougbert
souixchef2
