Lost my old pictures, do you know where these go?
84ShortBox
Kamloops, British Columbia
Nick
Lost my old pictures documenting the wiring.. I have the 3 connectors right behind the instrument cluster, does anyone know where they go?
Thanks in advance!
yevgenievich
Place
Name
Year
Model
Size
Two wire black one might be the glove box light, the bigger black ones might be power door related
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The gray and tan wires on the same connector are for the power door lock solenoids. The heavy orange, blue/white tracer, and black/white tracer are power door lock switch, the pink, (can’t remember other colors) are the power window circuit. On my 81, there is a power door lock relay above the emergency brake pedal, and should be matching plugs on each door. The connectors are pretty much idiot proof, they only plug into matching connector bodies and only fit one way. Hope that helps
84ShortBox
Nick
Thank you, that makes sense now.. I dont have power doors anymore which explains the confusion!
Bigskygearhead
