LMC Door / Interior Panels
68post
Indianapolis
Tim
454, TBD
Nice Craig, didn't know that those are available at my fav parts hse.
Doppleganger
OH-MI: Just like it sounds
Their basic door panels are decent quality and fit well, although there is no recess for a cloth or velour panel… the ribbed channels are formed in the hard plastic. So you can’t upgrade to a Silverado/Sierra Classic trim level. For my High Sierra, I bought the basic panels and all the trim/chrome/pocket/carpet ..you don’t need to buy an additional inner window felt seal (it’s already on the door panel)
Yes, the other pieces are of good quality. ABS plastic Headliner- A & B pillar trim - upper front/rear and side headliner trim...
color match all pieces for a consistent and factory look.
Did you have to paint any of the interior panels - and if so, what did you use? USA1 has the charcoal spray paint for about $20/can - haven't looked into if it needs primered, etc yet.
I see LMC has gray but it looks light. Debating on weather I need to get (bare) black or their painted gray to make into charcoal.
Thanks again for the info.
68post
Indianapolis
Tim
454, TBD
I saw light and dark gray in some of the panels on RockAuto
FireTruck1984
Michigan
1984 and 1984
Yes, the last interior I restored, I used the ColorBond Blue from LMC. I sprayed all the trim pieces and dash pad/door panels.
They don't have all colors..Classic Industries also sells a color match spray in factory colors.
3 light coats of color, then mat or satin clear.
86c10twotone
MD
Roy
Just bought the door panels and headliner. Both are high quality and look good. I added the carpet, chrome strip, and carpet trim piece to mine. Wanted the fully dressed door panels from the other place, but was not willing to wait the 12 weeks + to get them.
I just bought an entire interior from lmc that arrives Monday. I’ll let you know how it goes and the quality.
Craig 85
Nashville, TN
454/TH-400/NP205
@Doppleganger the Covercraft door panel I bought are the dark gray versions. It matches the Charcoal sunvisors I got from USA-1. SEM makes interior paints too. Same type of prep as described above.
Raybo135
Arvada, Colorado
Raymond
K10 Silverado
What was the other place and how dressed were they?
cutlerfab
