Little yellow wire
73c20jim
Sierra Vista, AZ
C20 2WD Custom Deluxe
350 CID 195/260 HP Goodwrench crate
What is the little yellow wire for? the one that goes from the left side of the junction box to the in line fuse.
I've searched wiring diagrams and cannot figure it out.
Mine is not connected to anything.
Thanks.
78C10BigTen
pennsylvannia
C10 BIG TEN
Thanks.
Thats funny its my picture lol i didnt have a working heater blower till i put a fuse in that holder and now i do so id say it works with the blower
73c20jim
Sierra Vista, AZ
Sorry for the theft. I saw that picture and It immediately reminded me of my issue.
My blower works, Must be RPO 7736774r8 as installed by prior owner. That should be POO 99999 for prior owner option installed without regard to any consequences.
It's yellow and a yellow wire goes to the points type distributor from the starter. I have HEI so I don't need that wire. But I can't imagine a fuse in line if its that wire.
78C10BigTen
pennsylvannia
C10 BIG TEN
I never traced it but like i said i popped in a fuse and my blower started workin. Idc about the pic theft, i just saw it and was like hey thats my truck lol if it helps you find what you lookin for then use it.
73c20jim
Sierra Vista, AZ
Thanks.
73c20jim
Sierra Vista, AZ
Just reading another post about the yellow wire. Talks about blower fan. Need to check this out,
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
What's not factory? The yellow wire.
Correct. GM did not put that there. That's some P.O.'s hack. You'll have to either follow it, or disconnect it to see what stops working.
78C10BigTen
pennsylvannia
C10 BIG TEN
In my case i know its connected to the blower because thats what didnt work till i put a fuse in it.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Well, there you go. Somebody's improvisation instead of solving the actual problem. Most vehicles end up this way. But I promise you GM did not install that fuse holder.
73c20jim
Sierra Vista, AZ
Already disconnected. Just dies there to broken in line fuse.
But same yellow wire, to in line fuse on two different trucks?
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I'm sure lots of auto parts stores carry fuse holders with yellow wire.
60Denais
