Led tail lights
pat
florida
pat
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
I had to replace the lenses on my tail lights. while I was there, I figured I'd upgrade the bulbs to led bulbs https://www.superbrightleds.com/cat/tail-brake-turn/filter/Cross_Reference_Number,1157,21,195:
After the install, I noticed they are not working correctly. When I'm not hitting the brakes, everything is fine. But when I hit the brakes, the flashing of the turn signal stops flashing and turns solid. Anyone know what's up with that?
I think you need and led flasher relay
pat
florida
pat
Wouldn't that just be built into the oem harness? The original bulbs perform the task. I don't see what would make the led not do the same.
ScottyB
Whatcom County, Washington
Scott
phantom
2 squirrels
OEM lamps pull more amperage and have greater resistance than LED lamps do. This can confuse the flasher if it is an OEM Flasher.
highdesertrange
kalifornia
mike
k30
I didn't know they made special flashers for leds. I have leds and have no problems but I have a heavy duty flasher. I think that is what you need. it's the light duty flashers the have a problem with amp draw. highdesertranger
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
LED flashers are known as "no load flashers" they're supposed to work with LED and fillament bulbs. Without one, the flasher doesn't have a high enough load on it to reset itself to flash (like an Resistor Capacitor circuit).
Can you throw up some after pics so we can see how that looks?
pat
florida
pat
Ah okay. Well eff that. I'll probably just go back to The stock lights.
350runner
tx
Ceasar
It's a one min swap. The flasher is located on the fuse box under the dash. Easy
highdesertrange
kalifornia
mike
k30
use a heavy duty flasher. I have had leds for 15 years and have never run a special flasher. highdesertranger
slowgo
wa
Blake
V3500 3+3
454, nv4500, 205, 4.56 rp
You can also cut pin #7 off the microchip on an electric flasher. Creates an open on the no load bypass circuit. If you swap led blinkers in three front this will also fix the fast blink.
350runner
tx
Ceasar
Good info here^^^
pat
florida
pat
Got them to work. Thanks guys!
K10noob182
