LED lights all around
Craig S
Stamford, CT
Craig
I got 2 light bars (22" and 40") 22" mounted on the front bumper and the 40" on top of the cab. How do I get the wiring to go from the light to under the hood? I bought aftermarket magnetic mounts because I didn't want to drill into the roof, any reviews on them?
Sent from my SAMSUNG-SM-G891A using Tapatalk
Crispy
Carbon County, Pennsyltucky
Suburban V1500
If the wire is thin enough you may be able to get it under the outside edges of the windshield molding but it still may get pinched when it goes into the hood. The proper way is to drill a hole into the cab. You can dab the drilled hole with paint so as to cover any exposed metal and use a weather tight grommet. Then run the wire down the A pillar in to the cab to the switch. The power wire will come from the engine bay through the firewall as usual. I understand you dont want to drill your cab but running wires on the exterior is ugly and could just become annoying with needing to repair it.
Craig S
Stamford, CT
Craig
Thanks for ur input. Im Trying to avoid drill
Crispy
Suburban V1500
I get ya, I dont want to make any unnecessary holes in my Suburban either.
How about a headache rack or roll bar in the bed and mount the light bar to that? Then you can also get some high mounted rear-facing LEDs in case you want to light up your bed or a tailgater.
