Leaky K5 tailgate
K5Rob
Maine
Rob
K5 Blazer
Hey guys I have been working on my
K5 power glass tailgate. Replaced the rotted sash, got the window all the way up now. Replaced the shot outer window sweep and it still leaks water into the interior. The sweep is seated nicely. I have the inside tailgate access panel removed and I found that this is how the water is getting to the interior. Is this normal? I put the panel back on to see if it would divert the rain water to the drains in the bottom of the tailgate. Since the top outer corners of the tailgate at each edge of the window sweep aren’t sealed I assume it is designed to take on some water and then drain through the bottom but I wanted to ask you guys first. Getting quite a bit of water in during a heavy rain storm
Edelbrock
Earth
Grumba
K5 Blazer
I would get inside and have someone spray a garden hose up into the air, so the water fall down on the window like rain, and double check where the water is coming in.
The window sweep is only there to keep the large amounts of rain a debris out. The inside panel needs to be installed to keep rain water out of the interior. That's why the panel has a seal attached to it.
K5Rob
Maine
Rob
K5 Blazer
Thanks bucket I saw the seal and that is what I was wondering. If it still leaks I will replace the seal
85 k20
