Leaf springs
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Mine are the multi leaf “ORD custom” springs, but not the whole kit. They asked me about a hundred questions before ordering them—there were definitely compromises made between payload capacity and flex. I went more flexy. Already had the grease able shackles, u bolts and shocks...still might need brake lines, but only asked for 2” lift. Their website used to state no ubolt flip kit for the rear on one tons because the spring plate could hit the frame.
As stated, still a lot to think about before slapping it all on and waiting for the 33” tires to wear some so I can justify new 35s.
You build a sweet truck. As you know, airbags for the rear so you can haul some fat chicks if required. And DO NOT attach the bottm of the airbag to the axle. Float it so you still have droop.
Are you geared for 35s? Might want to consider moving your front axle forward a bit and then trim the 'fang' off the fender.
ORD now has relocation plates to move the axle forward without using their awesome zero-rate 1" lift job. Maybe you could use that extra 1"
anyway. Also if you haven't already, consider a 1" body lift...NO MORE!
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
I see... Well, maybe just new stock springs will be enough for me.
Passenger side is less saggy:
Driver's side is almost riding on the bumps stops...
89GMCJimmy
ivan
https://www.sdtrucksprings.com/inde...OZ9y2YSN6WcATvKCoupYuHaQL3TG7biwaAkvMEALw_wcB
Stock springs here. If you plan on running any tire over 31" I would suggest a 2" lift min
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
I am debating between 30x9.5-15 or 31x10.5-15 when the time comes. So with the restored stock height of like 8 inches or whatever, a 31" tire would fit? The tires look kind of small, but my options list shows L78-15 tires as stock, and 235/75-15 is the accepted equivalent. They will only look smaller with new springs.
89GMCJimmy
ivan
Do you know what your gearing is?
31x10.5 will look perfect with stock springs. My 89' Jimmy came stock with 3.73 gears and 31x10.5x15
89GMCJimmy
ivan
15x8 rim
Make sure to check backspacing on rim before purchasing
3.75" or less on 15" rim The tie rod sits pretty close close
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
3.73 gears and a 400ci engine; I could probably pull at most a 5" diameter tree from the ground.
Would the extra leaf springs from that site fit any truck, within year application though.
I would keep the stock steel wheels. Maybe the 31"x10.5 would be too wide for them.
89GMCJimmy
ivan
A BFG 31X10.5R15LT Tire recommended rim width 7-9" I'm guessing your stock is in the ball park
3.73 gears with 31" tires should be perfect all around gear ratio
As far as springs go call before you buy. You could look around for a used stock 3 spring pack. I gave mine away to metal scrap guy.
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
I plan on making a sword out of my springs when I take them off.
89GMCJimmy
ivan
If you don't mind spending the cash I would go with Alcan springs in CO.
Prob close to $800 for the pair.
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
Thanks for the information thus far.
$400 per spring is a bit too much for me. I hope Atlas Spring is cheaper than that. SD Truck Springs seems like what I'll go with for ease of ordering and price.
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
You have way more clearance than I do but I only have the 2 leafs in front.
Scoots1 might have new springs, I'd guess that our 2 leafs were probably about the same height when new. Are your springs original?
I showed the photos to my father-in-law, he smirked and said "wonder how that happened..." He used to haul hogs with this truck, hence why it's on it's third engine and like 4th transmission.
78C10BigTen
pennsylvannia
C10 BIG TEN
Put it this way.... my 2wd with saggy front coils is on 31x10.5x15s. You will be fine with them on a 4x4
samelthecamel19
