Ignition timing
75gmck25
Northern Virginia
Bruce
You need to first decide if you want to keep that K3500 as a heavy load hauler, or make it more of a daily driver truck.
HD pickup tires are usually listed as load range E, or in the newer specs a load rating of 120, 125, or higher. To keep the full K3500 load capacity of your truck, I assume you will need an HD tire, not a standard Light Truck (LT) tire.
You can go to tirerack.com to find the sizes tires you want, and then check the specs for the max load rating. You have a lot of 17” tires to choose from, but also check the recommended wheel width and match that up to the wheels you use.
fnny6770
Pocatello
3500 camper special
What about 235/80/17 tires?
fnny6770
Pocatello
3500 camper special
If I recall the rims are off of a 2012 Dodge ram 3500, and since the hubs were a little larger I had to buy the special shims to make them fit correctly but so far they're doing just fine.
As far as a heavy hauler, I don't know what I'm going to do at this point it was my dad's truck he bought in 79 ordered it from the factory as a camper special, it has rust everywhere but the looks don't bother me, but to have it capable of hauling heavy loads that would be nice cuz who knows when I might want to haul a trailer to go camping;)
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Good advice here. I adjusted my 454 advanced until under a big load it would start to ping, pre ignite, on the gas I used, in this instance farm delivered 87. I ended up at 36 degrees advance, where a loaded 10000 lb trailer with my foot in it did not preignite. W/o the trailer it was a tire shredder, so that is my experience. My engine was a 75 8:1. 4:10 gears, rv cam, headers, air gap intake Holly 750 A/F set at approx. 13.8 full throttle. 14.2 running down the road. Notice the smoke in front of the truck, can’t hardly wait to get my new engine in there.
74Blaze
Nashville, IN
Gerald
K5/Blazer
By my tire size calculation spread sheet.
235/80/17 with 4.10:1 rear and 1:1 final drive would result in 2600 RPM @ 60MPH.
Let me know what your proposed tire size is (if other than that) and I'll run those numbers as well.
fnny6770
Pocatello
3500 camper special
With all this information is it recommended to have Porter vacuum on the vacuum advance or manifold vacuum?
jw23655
