Ignition timing
84 k10
US
monty
k10 silverado
1984 chevy k10 305. Ok I put a new intake manifold on my truck.the first time It had a bad leak at the front but it started. Fixed the leak now it wont start. So I found top dead center on the compression stroke and pointed the distributor just before the number one spark plug. I'm getting spark I'm getting feel but it won't start up. I keep raising the distributor up and turning the rotor hoping to find the correct position. What am I doing wrong?
Sent from my LGMP260 using Tapatalk
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
roundhouse
atlanta ga
justin
77,78,79,80 ?
Find the timing mark and rotate the engine with a socket on the crank to 0 on the crank pulley
Then find the number one cylinder and trace the wire back to the distributor cap
And lift the cap and make sure the rotor is pointed to that wire
To get this right I had to buy a new cap and I cut a some windows in the side of old cap with a dremel so I could see where the rotor was
Camar068
10 yrs Air Force
lol ouch!
84 k10
US
monty
k10 silverado
Finaly got it goin after realizing two plug wires were crossed. Thanks! Now my clutch is going i think because when I put it in 2nd or 3rd the rpms go up but it acceleration is behind. If that makes sence.
I just mark the distributor body with a sharpie, in line with the #1 terminal. When you pull the cap off, just line up the rotor to the sharpie mark.
roundhouse
atlanta ga
justin
77,78,79,80 ?
That works if it’s the same engine
If you’re building an engine or swapping in a new dizzy
When you add TBI to a carbed engine I couldn’t get it right
Cutting out a circular window in the top of an old cap leaving the spark plug wire terminals made it really easy
84 k10
US
monty
k10 silverado
Can oil leak from the intake manifold or would it more likely be the valve covers if I have oil on top of the motor?
climb-101
montana
seth
c2 crew cab
6.0 LS
it can leak in the front and back of the i take where it’s siliconed to the block or from valve cover gaskets. should be able to tell. i would guess it’s the valve covers but tough to tell without seeing it
I wasn't talking about making the mark before you take it apart. I'm saying install the cap, mark the distributor body where it lines up with #1 terminal on the cap, then remove the cap and rotate the dizzy until the rotor lines up with the mark on the dizzy body. Tighten the dizzy down and install the cap.
It's super easy and no hassle of cutting up a cap.
84 k10
US
monty
k10 silverado
Thank you rusty glad to be here
84 k10
US
monty
k10 silverado
84 k10
It's also possible for oil to wick up the threads of the center intake bolts, causing a little pool or two of oil on the manifold.
84 k10
US
monty
k10 silverado
That sounds about right, because I just replaced the valve covers and gaskets.
Twistedwhisky
