Identify that wire
80c10305
Sabin,Mn
305 v8
Can someone identify this wire and connector and inform me where it’s supposed to be connected??? I think it’s for the lock up torque converter but not real sure.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
I am almost 100% you are correct- that seems like the test point I used.
And, see below from an 82 Factory Service Manual.
80c10305
Sabin,Mn
305 v8
Truck is a 1980 c10.
So, I could connect that to a switch controlling the hot to test if lock up works?
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Not sure about your question, but, with a test light you can follow this test procedure.
My PO tied a toggle switch into the wiring from under the hood to allow it (the lockup) to be turned on and off.
80c10305
Sabin,Mn
305 v8
Ah. Ok. Now I follow.
jw23655
