shanegtr
- Sep 29, 2018
- Perth, Australia
- Shane
- R2500 Suburban
Ok, 454 TBI Suburban. Was running fine (but down on power last time it was running). Hasn't run for a while due to replacing water pump, fuel filter, fuel filter, spark plugs, crank pulley (no running due to waiting for parts). Anyway finally got everything back together tonight and go to fire it up and it just turns over with no attempt to fire. It will fire with some petrol poured directly into the throttle body but stalls quickly after. I'm getting power through the fuel pump relay with no issues. Applied 12V to the test point and dosent seem like the fuel pump is running (it ran a couple of times when I attempted to fire it up but now nothing). Checked the fuel filter to make sure there was no blockages (I could blow air through both directions - theres not a one way valve in them is there?) plus its a brand new filter.
I don't have an open circuit to the pump from the relay as I read 41ohms from the relay plug to earth through the pump.
So I now believe my fuel pump has died (unless someone can suggest otherwise). So question is whats a simple replacement that can go into an 89 burb with 40gal tank that would be suitable for future engine upgrades (I need it to fit first time as I live in a remote area in Australia and it will be ordered from the states - returns if it dosent fit is not an option)
