How much oil pressure during priming ?
Ypsik10
Ypsilanti mi
Chad
How much oil pressure should I have during priming? I can only get it to 20# 10w30 and a cheap gauge .
74 Shortbed
Depends on the pump and how fast you're turning the tool, you using a drill motor?
Ypsik10
Ypsilanti mi
Chad
It's an m-55 and I was using a drill going pretty fast
74 Shortbed
What are you using for a tool to prime it?.
Ypsik10
Ypsilanti mi
Chad
A priming tool from o reileys. How how should pressure go? I got my drill moving pretty good like I got 18-20 pounds ..
74 Shortbed
Should have more than 20lbs, is there a part on the bottom of the shaft with a slot?, if all you have is a shaft then you have a leak because you have an open galley there.
Ypsik10
Ypsilanti mi
Chad
Should have more than 20lbs, is there a part on the bottom of the shaft with a slot?, if all you have is a shaft then you have a leak because you have an open galley there.[/QUOTE
Here is s picture of what I have
Ypsik10
Ypsilanti mi
Chad
And another
74 Shortbed
Ok, you've got a proper tool, is this a new motor?? you have a leak somewhere or maybe the pressure relief in the pump is sticking, or the motor is wore out?? You should be able to get full pressure just using a speed handle to prime it by hand.
Ypsik10
Ypsilanti mi
Chad
Brand new rebuild brand new oil pump maybe my cheap equus gauge isn't reading properly or sticking it stops right around 18 lbs but I have seen it go much higher than that while driving
74 Shortbed
Possible or you got air in the line, might try another gauge. BTW, did you assemble this motor??..
Ypsik10
Ypsilanti mi
Chad
I assembled this motor yes I purged out the line and turned the motor over by hand got a little higher 23-24# would that it's not very warm in my garage have anything to do with it ?block is cold to the touch it's about 55 here and my garage stays pretty cold
74 Shortbed
Yeah, with cold oil you should have big time pressure,lol, I would try another gauge first that would be the quick and easiest to try.
chubhub6969
